Displays global OSPF information.
This command has no keywords or arguments.
N/A.
Not applicable.
The following command displays global OSPF information:
show ospf
The following is sample output from this command:
OSPF : Disabled MPLS LSP as Next-Hop: No RouterId : 0.0.0.0 RouterId Selection : Automatic InstanceId : 22 ASBR : No ABR : No ExtLSA : 0 ExtLSAChecksum : 0x0 OriginateNewLSA : 0 ReceivedNewLSA : 0 SpfHoldTime : 3 Lsa Batch Interval : 30s CapabilityOpaqueLSA : Enabled 10M Cost : 22 100M Cost : 20 1000M Cost (1G) : 19 2500M Cost (2.5G) : 18 5000M Cost (5G) : 17 10000M Cost (10G) : 16 25000M Cost (25G) : 15 40000M Cost (40G) : 13 50000M Cost (50G) : 12 100000M Cost (100G) : 10 ASExternal LSALimit : Disabled Timeout (Count) : Disabled (0) Originate Default : Enabled Always : Yes Type: 2 Cost: 10 Tag: 0 SNMP Traps : Enabled SNMP Trap Bit Map : 0xffff VXLAN Extensions : Enabled Redistribute: Protocol Status cost Type Tag Policy direct Disabled 0 0 0 None direct-inter-vr Enabled 30 1 0 None static Disabled 0 0 0 None rip Disabled 0 0 0 None e-bgp Disabled 0 0 0 None i-bgp Disabled 0 0 0 None isis-level-1 Disabled 0 0 0 None isis-level-2 Disabled 0 0 0 None isis-level-1-external Disabled 0 0 0 None isis-level-2-external Disabled 0 0 0 None host-mobility Enabled 0 2 0 None # of Inter-VR Exports: 3
The SNMP Traps and 40G parameters were added in ExtremeXOS 12.6.
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
